:P DLS CA12
:P DLS CA12
Dakle na prodaju navedeni AMP, ili zamjena za neki 4x kanalni, u istoj vrijednosti...
Number of channels 1
Amplifier class AB
Output power in 4 ohm 220 W
Output power in 2 ohm 400 W
Output power in 1 ohm 500 W
Mono bridge mode 4 ohm N/A
Damping factor > 100
S/N ratio, A-weighted > 100 dB
Frequency range 10 Hz - 35 kHz
Low level output No
Input sensitivity 0,25 - 5 V
Input impedance > 10 kohm
Input impedance, high level 100 ohm
High pass filter 15 - 150 Hz
Low pass filter 50 - 500 Hz
Phase control for subwoofers 0-180 degrees con. variable
High level input with auto start Yes
Power consumption (idle) 0,8 A
Power consumption (max) 60 A
Rec. power cable Minimum 5AWG / 16 mm2
Fuses 2 x 30 A
Dimension (W x D x H) 70 x 312 x 268 mm / 2,92 x 12,28 x 10,55"
Weight 3,8 kg / 8,4 lb
Nezz u cemu je razlika, a ni za ovo drugo jel popravljan ili ne, znam da radi savrseno!
