Capriolo cobra 180km !!!
Prodajem biciklo capriolo cobra, biciklo je kupljeno u capriolo centru u doboju placeno 320km, kvalitetno ofarbano u crnu boju !!!
Cijena 180km fiksno !!!
Ram:Hi-ten
Veličina rama:26” x 21
Viljuška/Amortizer:Steel rigid fork
šolje viljuške:
FP-H501 - 8 pcs headparts, thread: 1”X24T 22.2/30/27mm, W/key washer
Patrona:THUN - ROCKY - 122.5 mm, shell: BSA 68mm
Pogon:LANHANG - LH3187, LD-YST, 48/38/28,170 mm, steel CP, W/ chainguard
Mjenjač prednji:SHIMANO - TOURNEY FD-TZ21 band type, down-route, 28.6mm, for 48T, cs-angle:66-69
Mjenjač zadnji:SHIMANO - TOURNEY TX RD-TX31 6/7-speed, not rapidrise, W/riveted adapter
Ručice mjenjača:SHIMANO - SL-TX50, TOURNEY - index front / 7 speed rear
Broj brzina: 21
Zupčanik zadnji:SHIMANO - multiple freewheel sprocket, TZ MF-TZ21 7-speed 14-16-18-20-22-24-28T brown
Lanac:KMC - Z-50 - 1/2”x3/32” (114 links) (7 speed)
Kočnice:LOGAN - JY-927AE - alloy die casting brakes, 70 mm shoe, silver
Ručice kočnica:LOGAN - JY-332PAE - die casting alloy lever with plastic clamp, 2 finger, for V-brakes
Glave:QUANDO - KT-A15F front silver / KT-A11R rear silver
Felne:KRIPTON - KRYPTON-X 559-19, 36H, alloy double wall
Gume:CAMEL - 50-559 CB-529 (26 X 1.90)
Lula:LOGAN - 168-2/5 -steel stem with alloy cap, dia. 22.2mm, ext:100mm, bar bore: 25.4mm, angle +25 finish:ed black
Volan:WADER - GWSPSTEEL25.4 - steel seat post 25.4x300mm long, W/O clamp
Rogovi:LOGAN - LE-T-57-000BG, steel, black
šipka sjedišta:WADER - GWSPSTEEL25.4 - steel seat post 25.4x200mm long, W/O clamp
Sjedište:SELLE ROYAL - SHADOW
Pedale:FP-906, PP body, steel cage, 9/16”, with balls, with reflector
:cool:
http://static.pik.ba/galerija/2012-02/slika-227669-2012-02-1329216025-velika.jpg
Evo imam samo jednu sliku, ako neko bude bas zainteresovan uslikacu ga ljepse ! :icon_biggrin:
Fap
ja kupio polovno za 180 isto vako al podpuno sve isto samo bilo u orginal boji u plavoj :D
A i lici mi na moje, mada sam ja svoje prodao za 140 :D
Sve u svemu preskupo je
realna cijena od 120-150KM.
prva asocijacija ovakvog bicikla u promjenjenoj boji je ta da je biciklo ukradeno
Moje je bilo narandzasto crno, medjutim htio sam nesto da radim na njemu i eto odustanem jer hocu drugi bicikl da uzmem ukazala mi se bolja prilika ;)
Nije problem provjeriti da li je ukradeno ili ne, ko bude zainteresovan otici cemo do capriolo centra :cool:
